Server Issues
  • 7
Can we get a mod?
That has been that way on this forum software for a few years. Any forum that uses this software does that. I'm on a few forums that use it and it has had a few upgrades since it came out but for the most part it is still the same with stuff like that. I used to admin/mod on a forum that uses it and I never saw a setting where that could be changed. Maybe they've added it since then but not sure.
Was that a response to me? Ford-trucks.com doesn't have that issue.
Mostly completed with the update, however we're aware of many styling errors and are correcting those now. Please bear with us for a while.
I just clicked on six separate threads and they went well. Seems to have worked.👍
I think I know what could have been causing it and disabled the issue until a fix comes out.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
567
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
administrator
Administrator
Little man on campus
administrator
33 Thomas St.
ThxOne
    May 24, 2024
    May 23, 2024
