How to properly make a ground!!!!!
Is there a way to test the ground? To make sure that it's operable so you don't have to go back and do it over again when you put everything together.
With a multimer you check resistance/Ohms from potential grounding point to batt neg terminal.
Start by battery neg terminal to battery lug (1"away), then check the other end of the battery neg cable. This should give you the best possible ground, and zero, or maybe .1ohms or less. You can check your engine ground and body grounds. If you are going direct to frame, then see what the best frame ground you can find is first. If you are grounding to body, find your grounding straps in the engine bay, and check both sides. Getting a good baseline of all the factory and best grounds first, will give you a better idea of how well yours is going to be.
I like to sand the area to use as ground then drill a hole and mount a rivet nut. If the sheet metal is super thin you can back it with a washer. To keep the washer from coming off, insert the rivet nut, tape it down, then glue the washer with super glue. Now you can thread the rivet nut onto the rivet tool and done.
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
Single ground. If there is one thing car audio proves it's that the saying "Ground is ground the world round" is complete BS.
226
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Worlddre
Big Darkie
Worlddre
Charlotte, NC
    May 24, 2024
    May 23, 2024
