Modify port enclosure
Manu
25
Romania
Hello, i have an Hifonics MXs 12D2, using the original enclosure. I don't like how it sounds below 35hz, i have a small trunk, i don't want to change the enclosure. I want to ask you if i can get a better tuning, trying to modify the port. What i can do with it? Make it longer? This is my box https://ibb.co/9qfDvy9
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse engineer the net airspace and tuning of the box and go from there.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
985
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Using the limited info I could find, each driver needs about 30l of volume. Here is a great box design tuned to 37Hz, the ideal for 2 of these...
Manu
Manu
Romania
Buck
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
